- Nov 22, 2001
- 2,806
- 0
- 0
Nice worries lopri. Nice looking rig so far! I wish I had the patience you do for cable routing.
Turns out I can't use the fan duct with the HR-01. It has to be fully compressed to fit which makes it inflexible. It needed to make a slight bend to make the connection. Oh well. The heatsinks look nice. I'm going to install a 120mm fan on top of heatsink before overclocking.
I repositioned the HR-05 because I had plenty of room. An installed fan would blow air onto the memory. I may do that later. Here are pics:
Original plan for orientation
Fan duct attached to heatsink
Upgraded bolt-thru retention. Nice! Thanks Thermalright...
Need to add a 120mm to cpu heatsink and it's done
 Facebook
Facebook Twitter
Twitter
