I need some help i really was just trying to go buy a pc from one of the big companies but either they don't have what i want or they trying to rip me off. I mean seriously is the new mob called dell Lenovo and HP? So i have to build it myself.
I used to build my pc's but the last time i have build one is about 6 years ago. So i kinda feel like i don't know what i am doing. I read the parts guide sticky-ed here and it helped but i still feel like i don't know was new or whats coming. SO lend me your intellect.
1. What YOUR PC will be used for.
Gaming, graphic design, web design, office type stuff like spreadsheets and stuff, web and streaming and related stuff, so i guess everything.
2. What YOUR budget is.
$1100-$1500
3. What country YOU will be buying YOUR parts from.
USA and i prefer to buy my stuff from amazon.
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
N/A
5. IF YOU have a brand preference.
None
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
nothing really. maybe pop in my old hdd, but really.
7. IF YOU plan on overclocking or run the system at default speeds.
I probably might overclock it but its not that important.
8. What resolution, not monitor size, will you be using?
Wow dont know. but i do plan to run a dual monitor setup
9. WHEN do you plan to build it?
ASAP but there is no rush
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Windows. Plan on running 8.1
Ok so here is what i am looking for. I need a computer that i can work from home on and play on. I am starting over so this will be the first pc in my little line up. I am taking a serious look at everything tech in my house and this is the first step. I have stopped doing so much because my old rig was letting me down. so here is to getting back to the things i love doing.
my plan is to water cool this rig and i have been looking for a nice case to set this up on and i don't see any that does that. I want the water cooling components to be in a separate little compartment also but i don't want to case too big. Now the water cooling components have their own budget $400-$500. Also dont include the monitors in the budget either they also have their own budget.
So rig, water cool components and monitors and i need help with all of them
The rig
Case: Corsair Obsidian 550D $147
Motherboard: ASRock Z87 Extreme3 $147
CPU: i5 4670K $235
CPU Fan: Thermalright True Spirit 140 $50
GPU: Gigabyte GTX 780 $557
Memory: Team DDR3 1600 16GB $152
SSD : Crucal M500 240GB $125
HHD : WD Blue 1TB $60
PSU: Seasonic SS-660XP2 $150
DVD Burner: Lite-ON DVD Burner $20
Total: $1643
The Monitors
well?:
Water cooling
CPU Waterblock:
GPU Waterblock:
Memory Waterblock: maybe?
Radiator:
Water Pump:
lets get building!
$1100-$1500
N/A
None
The rig
CPU: i5 4670K $235
Total: $1643
The Monitors
well?:
Water cooling
CPU Waterblock:
GPU Waterblock:
Radiator:
Water Pump:
lets get building!
