Fanatical Meat
Hello there Fanatical Meat, I am building a 3900x centered system and considering the X570 Steel Legend as the motherboard of my choice. Did you end up with that board along the Ballistix Sport LT 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (BLS2K16G4D32AESB) you were talking about?
I am reading this motherboard is quite picky when it comes to RAM and I wanted to confirm whether they are compatible. If so, did you manage to run them at their advertised speed (3200 MHz) or maybe even higher since these are known to be excellent overclockers?
I was looking to PM you, but apparently as a new member I am not able to, so I hope you get to see this. 🙂
That model number looks familiar and yes it works at its rated speed and latency. I over clocked it to 3600 and it sort of worked but crashed when stressed. I did not change the voltage.
Also I picked up a second set from Amazon in December and I could not get it to boot with 4 sticks installed. Amazon seller so I’m not sure if it was a different run of memory or what but either set would boot, they would not boot together at any speed. Again amazon seller and only stuff I tried was booting at lower speed to see if it would work. I didn’t spend much time fooling with it.
Overall I like the board only things I don’t like:
Fan placement will be blocked by long graphics cards however I don’t think that would be a problem, just irritating to look at
Previous memory problem but again I did little research and little to get it to work
Chipset fan always runs however the speed can be modified. Chipset fan cannot he heard over the case fans and pump.
I’m pretty happy with it overall. Decent board, not too expensive, being able to add a thunder bolt add on card is sort of a nice bonus.
If I were buying today I would buy the new memory modules from crucial for the simple reason it will be easier to add more in the future.
Edit: Provided I remember I will run the crucial memory advisor and post the model numbers here.
Thing I like about crucial is they are serious about compatibility because they have so many corporate clients.
Edit 2: feel free to post in this thread to give me a reminder if I forget tonight. I’ll gladly do it with a reminder.
