Fanatical Meat
Almost been 10 years on my current system which wouldn’t have been possible without @VirtualLarry advice to change the cmos battery.
Machine is equally used for work which is web stuff and some light office things like excel or word, internet browsing and games.
I don’t have a firm budget as of now mid range or slightly above is great.
I want water cooling, I like how Corsair has a 5 year warranty. Don’t bother suggesting huge air coolers, I don’t like them and I want an option to add 4 sticks of ram.
I have no RGB desires other than it would be useful if a fan turned red if cpu was hot and another turned red if chipset was hot but certainly this isn’t required.
I do not want a case with a window, I’ll use a windowed case if the window can be put on the right side and smooshed against my desk to never be seen again.
Build should happen by end of September.
I already have:
Seasonic 850 gold power supply
I will have today 36GB of memory that crucial lists as support by every Asrock board and some MSI boards. I didn’t check any others, appears to be e-die.
Ballistix Sport LT 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model BLS2K16G4D32AESB
I’ll be going to microcenter for motherboard/cpu combo
I’m thinking a 3700x
Asrock X570 steel legend. Will this have enough PWM headers for fans & a pump? *Likely an open box*
www.microcenter.com
Corsair H115i Pro (always wanted to do water cooling)
www.newegg.com
Case I’m leaning towards be quiet because the top fan is covered. My cat loves to claw at screens, really want a fractal design define R6 but I know the cat will claw the crap out of it. Quiet is more important than cool but I don’t want something monstrously hot either
Be quiet 801
www.newegg.com
I really like this case but I’m back to open fans on the top which I know will get ruined.
Phantek
www.newegg.com
Video card will likely by my current 280x
Storage I’m not sure on, I’d like 1TB of storage. I’m up for NVME suggestions, I’d like to keep the cost under $150(ish) is there any real world difference between a good ssd vs 3.0 NVME drive vs a 4.0 NVME drive?
Bonus items:
I’d like as many fans PWM controlled as possible
I’ll likely put the radiator in the front and add another 140mm fan, add a 140mm fan on top total of 5 fans with 3 blowing in 2 blowing out.
Should I add a fan near the power supply?
Should all fans be on the same PWM or should radiator and chipset be on separate PWM controls
Give me any suggestions regarding the above items
Now to summon some posters I respect
@VirtualLarry
@Markfw
@aigomorla
@DrMrLordX
@Thunder 57
I already have:
ASRock X570 Steel Legend AMD AM4 ATX Motherboard - Micro Center
Get it now! Supports AMD AM4 Socket Ryzen 2000 and 3000 Series processors Power Phase Design Supports DDR4 4666 (OC) PCIe 4.0 x16, 3 PCIe 4.0 x1, 1 M.2(Key E) For WiFi AMD Quad CrossFireX and CrossFireX Graphics Output Options: HDMI, DisplayPort 7.
Are you a human?
Be quiet 801
Are you a human?
Phantek
Are you a human?
Bonus items:
@VirtualLarry
@Markfw
@aigomorla
@DrMrLordX
@Thunder 57
