Don't go for AMD. That's a really bad idea and you will have no future. An old AMD will also be an absolute disaster if you're intending on gaming at all.Will be mainly used for gaming. Only need MB and memory....oh and a aftermarket HSF.
Motherboard http://www.newegg.com/Product/Produc...82E16813128519
chosen for PRICE...wanted to keep around $100 Also it will be Bulldozer compatible.
HSF http://www.newegg.com/Product/Produc...82E16835103065
Also need advice for RAM...PC3/DDR3 1600 / 1333 / 1066??? Is 4GB sufficient, or go 8GB???
I am going AMD because I have a AM3 CPU pulled from dead motherboard of another computer. Will be overclocking, so need the after market HSF.
Yah prolly happens alot doesn't it <.< I think I've been late to the rescue like 50 times already.Shikyo, dude, he ordered already. Read the thread before posting
I don't consider you to be "late to the rescue" at all. I am very happy with my build. Just need to (eventually) get a Bulldozer for CPU, and upgrade my video card (again...EVENTUALLY)Yah prolly happens alot doesn't it <.< I think I've been late to the rescue like 50 times already.
I cant believe someone would recommend more than 4GB of RAM without even mentioning whether or not you are running 64 bit windows.
At any rate I think this memory is worth the extra bucks:
http://www.newegg.com/Product/Produc...82E16820231428
You might need the extra 1.6 fps it will give you.
Up and runningJust not overclocked...YET!
Still need to figure out how to do that and doing the research now. Need to update my rig in my signature now
I would LIKE to be able to get 3.8 like I had with the C2D
The ONLY problem I had was with the aftermarket HSF.....the screws didn't even come within a 1/4 inch of the standofffs they were supposed to screw into....rather a PITA, but I jerry rigged it so it is on.
I think I used WAY too much thermal compound, but temps haven't gone above 30
All in all....I am HAPPY...very happyJust now trying to remember what I had on the SDD before the format and reinstall.
