http://www.microcenter.com/single_product_results.phtml?product_id=0367692
Was told its the MC brand, can't be that bad can it?
Points well taken regarding PSU. I went with the Anteq for the extra few bucks and ordered the Rosewill case as well. Anything I need to do on the mobo as far as jumpers when the case comes in? I'll likely be back for pointers in couple days when parts arrive.
ATXPWR1 on MB has more pins than the connector on PSU, what happens with the rest of pins?
ATXPWR2 on MB is 8pin yet the PSU has 2 4pin wires. Which one do I plug into ATXPWR2?
Another problem: The wires from PSU are not long enough to reach ATXPWR2, what do I do?
Sorry, which Antec PSU are you referring to?
Antec Basiq BP350
The BP350 PSU should have a 20+4 pin connector to fit the 24-pin header on the motherboard. Are you quite sure you didn't simply neglect 4 pins hanging off of the main connector?
There is no 20+4 from the psu, However there is a 20pin and 2 separate 4pins. Can I just stick one of the 4pins along with the 20pin into the header on the MB?
The newegg specs list only one 4-pin CPU cable. You can safely use one 4-pin connector in an 8-pin socket, and if your unit really has two separate identical 4pin CPU power cables, it doesn't really matter which one you use. If your unit actually has a cable with 4+4 pins (i.e. not two separate cables), use that.
That's... unfortunate. The PSU is ATX compliant so it should have wires long enough for a standard ATX motherboard in a standard ATX mid tower case. If it really isn't long enough, you have two choices... get a different PSU or buy a cable extension.
Oh, then it seems the other 4-pin cable is for the motherboard 20+4 header. The 4-pin connector for the 20+4 header should look like the one on the right. It is keyed differently from the CPU power cable so you should be able to tell which is which
It probably doesn't reach because it's designed to be used in a case with the PSU mount location at the top.
I guess it would've been a good idea to pay a bit more for a PSU with longer cables to begin with rather than having to buy an extension. I wasn't aware of this, and I should've checked the newegg reviews
Can you still return it?
Does it matter which of the 4pin power cables I plug where? They both look identical.
