new bracket for GPU liquid cooling
Some testing pulled from a Korean review site.
http://www.coolenjoy.net/bbs/boardc.php?id=review&no=18105&p=5
They test a ton of cards with some interesting results. The results on the 7970 are not good because they didn't use a shim. Also, odd power consumption on the GK110 cards.
Excellent review. VRM temps are fine with the G10 for gaming, 70-80C is great compared to most custom cards that have it in the 85C range.
Mining would probably hit 100 to 110C with the fan only, without heatsinks.
Also, power consumption makes sense, GK110 will boost higher when it runs so cool, using more power. Whereas Hawaii running at 55C versus 95C will cause a drop in power use due to less leakage.
Ahh.. that's right I forgot about that 🙂
Found another review - I will just copy and paste from my post on OCN
Here is a review using an NZXT X60 with a G10 - http://www.overclex.net/articles/test-du-nzxt-kraken-g10-et-du-kraken-x60/
Temps do look better vs. a single 120mm or 140mm vs. other reviews. Keep in mind his fans were maxed out in the overclocked tests, but even on auto the temps look better.
Just got mine in today. I will do some testing this weekend and share my results. Just got done modding my Corsair 500R yesterday as well, so it was good timing. I will have my GTX 780 Lightning attached to a Thermaltake Water 2.0 Extreme.
