Question new 4k monitor S32B800PXW lagging
hardcore_gamer29
942
20
samsung monitor 32 inches 4k 60hz is lagging if i maximize minimize etc. in windows animations and transitions but monitor is running at 60hz. What to do?
17,188
Check to see if you can switch the color profile of the monitor in its OSD settings to something like Adobe RGB or DCI-P3 or sRGB.
Or try to download the profile for your monitor from the Samsung website and load it up in the Windows display settings.
17,188
Can you tell if i should get spiderx pro or elite if i do only adobe all apps like premier pro and photoshop illustrator etc
Not sure if that will help. Your monitor doesn't support AdobeRGB colorspace.
Choose the sRGB mode and see how the colors look.
You shouldn't really need an expensive color calibrator since your monitor is supposed to be factory calibrated.
Reactions: hardcore_gamer29
17,188
caliberator works only with adobe rgb?
No. I meant that you are using Adobe applications and AdobeRGB would make more sense for them but your monitor doesn't support that so what's the point? If your monitor is factory calibrated, I don't think you will be able to do better than them. Don't waste money if you have never used a calibrator before. You need to know what you are doing. If you can take your monitor to some professional calibrator, that would be a better idea.
hardcore_gamer29
942
20
looks like colors on this screen already pop and are accurate than my samsun 2233sw tn model of 2009? Looks like i am new to accurate colors :)
