Never Using Prime95 Again...It's Ineffective
Originally posted by: MrControversial
I ran the one that stresses memory. I don't have a floppy drive so Memtest86 isn't an option.
The setting that stresses memory is a joke if you are testing your proc. It only uses around 3-5% of your proc but most of your memory. If you used the small files test it would have errored out with a quickness.
Originally posted by: jpeyton
Why don't you guys use S&M 1.3. That thing will crash your computer FAST!
They have S&M 1.51 out now and I believe that no other program can heat up a CPU like S&M 1.51 on the FPU setting. It beats Prime95, CPU Burn-in and even CPU Burn. It takes my CPU about 3C higher than CPU burn which is the second best. However, S&M 1.51 cannot crash my system when Prime95 on the small files (setting #1) can do it in a matter of minutes. I kind of use all of these programs to test for different things. One program cannot do it all IMHO.
So far it is OK as a temp producer
I set everything check..test is long with 100% cpu...max temp is 53.5c but seems to stay around 49's....holding 100% cpu utilization....I will wait untl whole test is done but I dont think I will see nay issues cause heat wasn't an issue for me...
sidenote...my prime95 temp at this speed is 50c with a occasional flash of 51c so I was probably like a 50.2 or someting..that is using speedfan which is also what S&M uses...
FH gets my cpu to 49-50c so basically I am not see what is so grand about this...Sounds like a bunch of morons in the limk running the blende test of prime and then running this...blended test usually only gets me to 48c max at this temp....either waY I am seeing no great swings as they have stated....
Update: test completed fine JPEYTON!!! NO fast crash here!!!
Max temp I saw was 53.9c which is about 3c higher then my highest p95 temp....
I may use it in the future but seems not long enough perhaps....How can you make this thing run like 24 hours??? Was there a settting I didn't see???
Edited to denote version 1.5; and S&M is a good way to do extreme load testing of your power and cooling systems. A weak power supply will definitely make it error out; as will poor CPU, memory, or motherboard cooling (caps get burning hot too).
i dont think s&m is a good stability tester....why? cuz it gets "unusually" hot...hotter than a system would EVER get from any tasks i can even think of
what other program or game would get your system that hot?
since you cant really replicate it (at least i cant think of a way, unless you just have poor caseflow in the first place), it doesn't really necessitate a place in my stability testers toolbox
i can guarantee you that if you slap an extra five to ten degrees celcius to 95 percent of peoples' overclock here that it would cause otherwise "prime stable" overclocks to be worthless.
if you can pass memtest for 24 hours and then prime for 24 hours and say 3dmark or any game looping for 24 hours....thats pretty darn stable, even if its "only" at the temps that those programs are able to muster up...which is pretty much "normal" use
sure maybe during the summertime the temps would be equal to what s&m can cause your system to become but i'll just wait till summertime to drop my overclock 😉
edit: its a damn good cpu burner tho!
Originally posted by: Duvie
Originally posted by: zakee00
memtest 86 didn't do it for me, i pass all night long but i run windows based memtest and i fail after ~30 minutes.
that doesn't make sense....The windows test is far less accurate...
reasons??
1) It doesn't test all the memory...Only test non used ram which in most cacses can be 25%..
2) Any background apps or programs suddenly using th eram can possibly cause an error....
This program is not even ballpark...I suggest you get the memtest86+ cdrom iso version and make sure you are properly configuring it...YOu want to make sure you do all the test and make sure cache is on always....
If you do it like me you will never see an issue, unless heat is a factor. It seems like running it exclusively at night is not necessarily the best either. Likely the room is cooler at nigh and thus the stress may not be building up the max ram heat.
Just review your logic of what you said...It makes no sense...
My personal guess is that he was referring to the original "Memtest86", and not the newer "Memtest86+". I've had one occasion thus far where the original did not pick up any memory issues, whereas the newer version, and other diagnostic programs did, so I don't really trust the original Memtest86 anymore myself. I'm guessing that by "Windows Memtest" they were referring to MS's Windows-based memory-testing tool, which I think actually tests memory via execute-based fetches.
reasons??
Doesn't matter...the fact is the windows based one only test unused ram and since about 1/4 of moine is tied up at bootup then it is not testing all the ram...NOt effective enough....
Ok, I guess what I was trying to say is that:
1) I agree with you that the Windows-based memory-tester offers only incomplete coverage of the DRAM address space, however the testing that it does perform on that address space is generally effective.
2) The original Memtest86 may have complete coverage, but based on my experiences, at least for a KT400-based system, the tests are useless and utterly ineffective.
3) The newer Memtest86+, which has specific support for newer systems/chipsets, has both complete coverage, and effective testing.
So while 1) may not be effective enough, it's still marginally better than 2), but really, use of 3), in conjunction with some additional testing tools is probably best. Which is what you suggested as well.
:thumbsup:
Prime95 is not a good memory stress test. I use it for testing the CPU.
BTW, prime keeps my CPU at 100% even when using 90% of my memory. The only way it will use less than that is on a SMP system, or if you use more memory than your system has available. In the latter case it will be too busy paging to and from the drive to do much of anything.
i ahve been having problems with blend and posted a thread about it
Post
blend keeps failing no matter what i do, could it be that it is trying to use too much memory, i have had that issue where cpu drop to liek 20% usage and prime never goes to the next step. should i lower the max mem to use and by how much or to what, how would i determine that?
In my experience, Prime has been a great stability test. If I had stability problems, Prime would always bring them out. I use it to test overclocks, and I haven't had a crash yet.
thats why i prefer OCCT....OCCT is more sensitive than prime...i had situations where prime needs an hour and OCCT complained after 3 mins already.
regarding memory testing:
YES...prime/occt (assuming you use the option to test plenty of your ram) is a GOOD memory test too..actually better than memtest.
memtest can run fine here for hours.....but under the same config i could fai OCCT/prime in a few seconds....memtest is only good for testing whether your mem is defective and whether it gets enough voltage.
(Eg, test #5 is good for testing voltages for your mem..if it passes 15 runs #5 your mem is ok and memory voltages are ok too)
STILL - you might have to tweak timings afterwards to make it run stable in windows - thats when you use OCCT or prime.
