Never ending level flash game! Addictive!
my problem with the game is that the levels is that there's nothing smart or clever about the puzzles. They're just annoying.
Originally posted by: silverpig
I was up to 70-something, then firefox updated and restarted. Now I'm back at the beginning. Screw this.
Just skip to the next closest level.
Originally posted by: Epic Fail
Got stuck on 43, dragging the text, I can't seem to release it and can't find the hidden button.
Yes, the drag and drop sucks since it often won't let you drop it. I had to restart a few times to get #43 to work. Just drag it far enough for "invisible button" to be centered over the capital 'L' in 'Level 43'. Your invisible button will show up in the bottom corner. It really isn't a button, but something you drag.
I got to #57, and even somehow got the blue box to change to a symbol. But from there I gave up.
Level 43 is a pos. I can't get the text to deselect from my mouse...
edit: 78 😕 nvm ima tard
Damn it. I have a paper to write. must. stop. playing.
I can't get the text to deselect either. how did you do it?
I just repeated the whole level four times before I could get it to work. I was very deliberate about staying on the screen, and not moving my mouse while releasing. Really just blind luck.
I ended up doing the same thing. Good thing that level 42 was a password level. I had to retry about 5 times.
Originally posted by: DisgruntledVirus
I'm missing something on 47....
I'm not sure the best answer, but, I filled the screen with the panels and then the exit appeared.
Originally posted by: Lummex
Why can't I figure out 57. Hint anyone?
Stuck on level 57 at the moment.
EDIT: Got it, that was a bit obscure.
I'm stuck on 57 too...
Assuming you got to the symbol, think remote control.
Assuming you didn't, try dragging the squares.
EDIT: Oops, nevermind. You don't need to drag them. You just need to click them in a particular order.
Spoiler: Click them in a pattern until the center box changes. Then don't click any more. You just have to guess the right word. And note, there are multiple words for that symbol but only one works.
