- Mar 18, 2005
- 5
- 0
- 0
I have aliant DSL and i had to install software to connect to the net. I used to have cable internet and i never had to do that before. So when i wasn't using the router after i installed the software for the net i get my firewire ports and my local area connection and a High-Speed Connection Manager in network connections. The high speed connection manager is a wan miniport(PPPOE)
After i had the net working i unhooked everything and put the router in and hooked everything back up. As i said everything is wired and the wireless capabilities are turned off.
After doing this i ran the xp network setup wizard and i can get a connection working on my system but i cannot access second computer and the second computer cannot access my computer or the net.
There are tons of options for the router like using DHCP or PPPOE and i'm not sure what to use. I read that you shouldn't use PPPOE if your modem is using PPPOE. Not sure what that means.
I tried setting up both pcs in the "my computer connects to the net through a hub" option and i was able to get both computers networked but then as soon as i dial in to the net the computers loose their connection to each other and my main computer is the only one online.
Not sure what other info would be important.
Thanks for any help you can give.
