:brokenheart:
WELL ALL I HAD TO DO WAS DISABLE MY ONBOARD NIC AND THAT WAS IT!!! SOMETHING THAT I SPENT AT LEAST 6 HOURS ON - TOOK 30 SECONDS TO FIX - I WILL BE KING of the KNUCKLEHEADS TODAY - BUT I DID LEARN ALOT....
THANKS FOR EVERYONES INPUT -
Dan - moo
Here is the situation - I moved my desktop over from Win2K SP4 to XP PRO SP2 -
And this is a fresh install and NTFS format of XP Pro... right... Anway with Win 2k I had no problem seeing my neighbors network (he has wireless cable modem - that I use to pick up his signal no problem - of course he knows)....
WIth Win 2k - Could see his signal fine and get on the internet - no biggie - I also had NETBUEI enabled and all worked great...
With XP I can see him fine no problem great signal - it's just I can't get on the internet - What I'm I missing - I also have NETBUEI enbaled with XP - it does support it...
When i view wireless networks it says that"windows cannot donfigure this wirless connection...." - yet it sees the wireless network no problen - it's just no internet...
Please help - using laptop right now... so I can see post ASAP - I really need some help - I am hoping the fix is easy...
thanks,
Dan - sweating it out in the Boston area...
Dan - moo
thanks,
