quite honestly, any decent board/conference room table is going to have power and RJ6 jacks in them. Not cheap by any means, but pretty standard nowadays.
It's a niche market. Not too many companies will be installing more than a handful per year.
Here's another.
Here's another.
http://franzconferencetables.com/
Thanks
If laptops would just use common 12V inputs, you could actually put a beefy PSU into the table, and have retractable cables.
But of course, that's just a pipe dream.
It's imperative that 9.6V, 11.2V, 14.8V and whatever else is used.
Yes, it might make battery design a bit more difficult, but some external connectors already have enough power to run most ultrabooks. (USB 3.1: 60W)
The point of this is to keep cables going from the table to the wall. Try setting up 6 laptops at a conference room table, now walk around the room.Executive status symbol. You'd still have power bricks sitting all over the table and most iproducts don't even have ethernet anymore.
Personally I'd hack some Ikea tables to hide power strips and make sure the room had excellent WiFi coverage.
Ya, not a lot to choose from and on the expensive end. We may build our own.OP, have you tried using a google image search and check the results for retailers?
that feels like it would have been really useful 5-7 years ago.
do they even make laptops with NIC's anymore?
Yeah I hate how everyone has to make their own "standards". Would be nice if laptops used 10-14v so they could be plugged into typical 12v systems (13.5v float voltage being typical)
Pods seem better for that many, from the first link.Try 20...
What I'd rather see is one of those Microsoft Surface tables with wireless charging ports.
Toss your laptop on top of one of those, and not only will it charge but it will give you the opportunity to sync to the other devices connected to the table.
They should put high frequency induction coils in the table too, Use a metal coffee cup or throw a couple metal bolts in a regular mug and it will keep your coffee warm. Actually, certain types of metal may add an interesting taste to the coffee. This could be a new hip thing to do at the office and it would pave the way to revolutionizing synergy.
Wiring is also a concern, for network you would probably want a switch down there, one cat5 wire to the table. Power would likely need a dedicated circuit. How do you get both to the table? What's the floor made of? Drop from the ceiling?
