Hi all,
I am trying to move from a old Windows XP machine to a Windows 7 PC.
This machine is used as a gateway from the Internet to a Intranet, so it has 2 NIC's ( both static IP's)
The Windows 7 is a fresh install, and works perfectly until I try and Clone the paramaters - IP's and Computer name. Then the Windows 7 machine will not ping. It does get to the internet and it will ping machines on either LAN OK. It is not seen by the other machines on either network.
Advanced IP Scanner finds it from other machines, but I cant ping or tracert from that software either, Even if I change to another set of IP's and Computer name, it still wont appear on the network. The only way I could get it back was to reinstall windows 7, and then all was well until I tried to clone it again, then It once again quit working. I thought it might be the APR Cache, and Ive cleared those.
Any Ideas? This one has me bewildered.
Thank You.
Joe.
Thank You.
Joe.
