This problem has happened on a few different machines so I'm going to list the actions and then you can make suggestions.
System is installed with a fresh install of WinXP Pro SP1. Next the drivers for everything are installed, then the Blaster Worm Fix. The internet is then connected, DSL with a static ip and all the windows updates are installed. After the reboot from windows update the network card appears and disappears continually. If the network card is set to DHCP the card will sit fine in windows. Any input is appreciated.
Scope!
Scope!
