I am not sure if this is the right place for this, and this is my first post here also, but I really don't know what to do anymore...
My network cable "explodes". Images below. Let me line up all the strange facts:
Help... Any one ever seen this before? Is it possible for a network cable to just snap/explode somehow?
High res version for upclose view: https://dl.dropboxusercontent.com/u/2300830/cablexplodes.jpg
Some ideas and reasons as to why it is impossible:
Animals
No because: no droppings, no bite marks, and if it were mice why would they go through the trouble of biting through the duct tape if the cable an inch further is exposed. Also the wood splinter does not fit this scenario.
Door cut the cable
No because: door did not move during the night, door is not sharp enough at the bottom, the electricity cable is undamaged, I put extra protection around it, and I tried smashing the door as hard as I could on the cable and it did no damage at all to it.
Cable pulled itself in this bend apart due to being pulled in another part of the house (there is a dog somewhere else)
No because: there are multiple tight bends along the cable, it could have snapped at any of the other ones, also I tried pulling the cable over but you need a massive amount of strength to get the cable to snap. This does fit the wood splinter though.
EDIT: Extreme detail shots :https://dl.dropboxusercontent.com/u/2300830/veryhighres.jpg
- This is the second time it happens. First time was two weeks ago. Happened at exactly the same spot twice.
- This was a brand new quality cable.
- I have been living in the house for years and the cable has been there for years. Suddenly two weeks ago this began happening.
- This happens during the nights. The cable is fine in the evening, and broken in the morning. No one is around in this part of the house when it happens.
- The door is never closed + it is not sharp anyway at the bottom.
- There is a yellow electricity cable next to it, that one is undamaged.
- This time around a small piece of the wood of the door frame came off even, so it ripped a splinter off.
- I had even put bubble wrapper plastic and duct tape around the spot this time, and it has torn right through that.
- As you can see in the images it shattered the cable and the plastic in a 100 small pieces.
- The pieces can also be seen pretty far away from the cable, so it must have happened with a considerable force to throw the debris that far.
- There are no bite marks and there are no animal droppings nearby. Nothing that indicates mice or so are chewing on it.
Animals
Door cut the cable
