Originally posted by: Eli
Originally posted by: LiQiCE
I've been using Mozilla v1.31 for the past week or two (I was a 100% IE user since v3.x even when it was SLOW), and I really like Mozilla v1.31, its almost as good as IE in rendering pages (in terms of what it should look like), and its rendering speed is FAST, plus I like the tabbed browsing. The newer versions are very stable too which is nice
Ahh.. Tabbed browsing..
I don't know if I could get used to that. I like having 40+ IE windows open....
I'm fast with alt-tab.
And after a while, you know exactly where each window is, and what it is..
True that.
But I still use the tabbed browsing. It uses
MUCH less system resources. I can have over one hundred fourty tabs... try doing that with 140 windows. Your system might even crash and need to be rebooted.
Besides Mozilla is 100% just as fast as IE. The only difference is Mozilla is not preloaded into memory like IE is. If it were, you would not see a difference... or if you did, it would be so miniscule you would not even care.
In any case, I do not want to turn this into a browser war. I use Mozilla because it is fast and thousands of times more secure than IE/O(E). Not to mention all the built in goodies to contol how well the internet can be
Those are enough reasons for me. They might not be for others.
