Like the title says I am having problems with my Netgear WGR614v5. The router works fine after it has been power-cycled for maybe 2-3 days, then it starts having problems. The first thing to go, it appears, are HTTP packets. It seems to be dropping them like crazy. In netstat I just have a bunch of TIME_WAIT messages for that IP but nothing ever really loads, and it ends up timing out. After that (usually a few hours) other services start shutting down, SMTP, POP, AIM, online gaming etc.
The only thing that seems to (temporarialy) solve the problem is power-cycling. It just started doing this a few months ago at random. It affects other computers wired or wireless, so I know it isn't this machine specifically. I know it isnt the cable modem as I left one computer connected directly to that when I went on vacation and it worked fine. I have updated the firmware since the problem has occurred (it was running the newest version anyway) and even tried the beta firmware (using that now) and it hasn't seem to made a difference. Other than buying a new router I don't know what else to do.
TIA,
Pete
TIA,
Pete
