Netflix updated their UI. Considering a massive protest.
twinrider1
4,096
64
Ok, not going to stage a sit-in, or chain myself to their headquarters, but I liked the old UI. Instead of everything being at the bottom, now some things, like subtitle control, are in the top left corner. More clicks, less intuitive.
Amazon Prime....now there's a UI that desperately needs to be redone.
Edit: I'm talking about the controls during a show, not the initial thumbnail list of what's available.
twinrider1
4,096
64
Home internet through the PlayStation3. I just noticed it last night watching Siege of Jadotville (good flick, if a little stiff and formulaic).
twinrider1
4,096
64
Yep. But I just checked using Ruku on another tv and getting the same new interface.
AznAnarchy99
14,695
117
Amazon Prime's TV app is just trash. They split the show's HD and UHD versions for no reason.
OutHouse
36,410
616
i cant stand that i have to search for my favorites list, it used to be at the top. so irritating.
brianmanahan
24,672
6,036
pretty much anytime any UI gets a new design its worse. doesn't matter what it is or what platform its on, its always a change that is bad
someone should transport you back to 1997 and make you surf the web for an afternoon to repent of your anti-mobile-first blasphemy
13,992
But it's more modern!
I agree though it seems in the past years the trend for UI design has been extremely terrible. Companies change their UIs just for the sake of change, and make them worse in the process. Just look at what Windows has become. Makes me want to vomit. Another good example is Youtube. They keep making it worse every time they make a change.
The comment section is a shit show as well, it's like if they're trying to make it worse than the actual comments.
Ruptga
10,246
207
Must be app? I don't see any difference in the web UI on my desktop PC.
Yeah. I noticed it the other day on my 360. The other worked and looked fine, this looks like they gave it to a graphic design student for a week then shipped it.
futurefields
6,470
32
I want to know why Netflix doesnt give you a way to sort by ratings and what not.
Like on my Roku TV, if I want to check out the Horror movies, I just scroll down to where the Horror section is. And it will have like 74 movies listed??? What about the rest? I have to use the Search function and hope to find what I am looking for?
How can I browse ALL the horror movies? And sort by rating?
Reactions: Zstream
lxskllr
60,697
11,065
Because before first release they worked hard to make it right. First revision refined the interface after field testing in the wild. Behold the perfect interface!
Uh, oh. Now we have to change to be "modern", and make people think they're getting something new. The service isn't changing, so that leaves the interface. If it was perfect before, that means any change will make it less perfect, and here we are...
pcslookout
11,964
158
That is easy.
MtnMan
9,445
8,853
Redo the UI, you mean kinda like Anandtech.com and now 1/3rd of the screen is wasted....
>>>>------------------------- that part over there --------------->>>
nakedfrog
63,307
19,689
I keep forgetting some of you have to deal with that. It seems terrible (if I log in from the other PC I get a rude reminder as well).
