Netflix for Android, now modded to work on most Android devices
bonkers325
13,076
Try running the version that doesn't check your device. I can run mine fine. Takes a little bit to buffer but after the initial few seconds its all good.
Sent from my ADR6400L using Tapatalk
Bateluer
27,730
8
I did. Didn't try the second apk in the thread. Also, I only checked it on 3G because I was at work. :p Once I get home, I'll experiment some more.
What ROM are you running on your TB?
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
I tried this on my vibrant last week, still wouldn't play videos. Of course an interesting notion - how comfortable are you with providing your netflix credentials to a hacked app?
ponyo
19,688
2,811
I'm running the device check disabled version on my Galaxy Tab running stock Gingerbread. Videos work fine.
AnMig
1,760
Using my nook color with cm7 7.1 gingerbread overclocked kernel.
Loads and plays video but playback is fast on the first version even faster on the second version.
Audio sounds like Alvin and the chipmunks. Maybe my device is too fast :) or Netflix disbaled the hack.
cronos
9,380
26
101
This is what happened to me (and a lot of others) as well, and people figured out that there is a way to fix it by modifying two lines on your build.prop file to fool the program into thinking that your device is an HTC G2. Search around, you'll easily find this hack.
Note that by fooling the app, all other apps may be fooled as well so some of your other apps might go wonky afterwards. I personally tried it, confirmed that it worked, and changed it back.
poofyhairguy
14,612
318
Its not a big deal on a Nook Color, because almost no apps are looking for one considering that "officially" it can't get onto the normal app store. Plus with the build.prop method you won't be left in the cold if Netflix updates the app.
Here is how to do it:
http://forums.anandtech.com/showpost.php?p=31702718&postcount=96
Works great, no chipmunks, I use it daily.
Nov 26, 2005
15,194
403
Installed the apk from the first link and 'download link 1' and it installed fine and booted up asking for my member name and password, lol but i don't have an account there..actually I never thought about signing up for one.
Nov 26, 2005
15,194
403
that's probably due to the conversion.
poofyhairguy
14,612
318
Videoquality is not so good in the large nook screenthough.
Actually I think its pretty good (once you do the skip forward skip back trick to get at a better quality stream). At least as good as Netflix is on my wife's iPad, or when I use Air Video on my iDevices. Better than Hulu.
Tablets in 2011 is all about taking those sky high standards that we have experienced with modern quad core computers and doing your best to forget them. I try to only compare my Nook to my ten inch Netbook, and it beats it in every way.
hanoverphist
9,867
23
droid X 2.2.1 rooted but not modded at all. i updated to flash 10.3 first, like i saw someone else had done, and its working perfectly. pretty decent quality too, especially with the less-than-stellar signal i get at my desk. i havent seen the fast playing tho, guess im lucky so far.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Hmmm... this might finally get me to upgrade my Nook again. Don't really want to run much more than just updated stock rooted though so I'm not sure how well it'd work. If I have to run CM7 or something it might not be worth it. I still use mine as an e-reader more than anything else.
MagickMan
7,460
You could go CM7 and use Aldiko, it's so damned good I don't even miss the stock reader.
quikah
4,206
750
Works on my stock Optimus V (no root) using the device check disabled apk, but there is a green bar across the top.
Indolent
2,128
Anyone know if it can download for later playback or does it only do streaming? I'm thinking for airplane use.
