I disagree with a lot of posts in this thread that blindly pointed the OP to LINQ to SQL. I don't mean to offend anyone, but have any of you actually stepped through the debugger to look at the SQL that is generated behind the scenes for some of the complex LINQ queries. Have you looked at the metadata-related queries that ADO.NET sends to SQL Server at runtime using the SQL Server Profiler before each DB call is made?
Good luck querying tables with more than a million rows, populating data warehouses, or hosting database-heavy Websites. LINQ to SQL does make things a lot easier, but those things are extremely unoptimized. In general, any decent programmer must learn the basics of optimally querying a database and understand concepts like database indexes. You can put a "where" LINQ query which searches for 10 different things... if the query is not covered by an index, you'll be royally screwed in production.
To the OP: please take the time to learn the basics of ADO.NET: DataTable/DataView, DataSet, disposing connection objects, utilizing "using" blocks, etc. And stay away from SqlDataReader objects
. In general, unless you're dealing with Web Services, DataTable is usually the fastest since all the data is "binary." DataSet is OK for multiple tables, but it is extremely verbose because it is XML-based.
Once you have your data in memory, you can do some wonderful things via LINQ... for now, LINQ to SQL has a lot to improve.
