freemanteo
I have not used my external burner for 2mths as i used my dvd/cd-rw combo on my lappy, and i hook it up and used the same Nero 5.5 that i have been using, i cannot get it to burn one CD-R successfully!!
All i get is coasters, the program "hangs" with the timer counting but the burn stalls. Or it gives a burn error. i have tried MP3s, regular data, even a 8mb file, but all is coasters, incomplete.
I tried changing the ram buffer from auto to manual (70mb), but it does not change a thing.
The reason is because i got some cheap K-hypermedia CD-Rs, and whenever i burn with my DVD/CD-RW combo drive, it works fine but whenever i used it on my indash car cd player, some part of the cd, the songs are distorted.
So i wanted to see if my burner or the CD-R is the problem for the distorted songs.
Pls, any advice is appreciated. Thanks.
