Nerds: School Me
Anubis
78,712
427
tbqhwy.com
I don't want to buy CDs any more. Is there a legit source for very high quality downloads? What format?
olds, HDtracks.com is pretty much your only bet for really high quality downloads. the downside is they dont offer everything. its a limited selection of music
amazon and google let you download decent quality mp3s but they are still mp3s
just keep buying CDs and ripping them as FLAC or whatever loseless format you want. its what i do and i am very much a nerd
edit. actually bandcamp also has FLAC downloads but its more for new indy bands
T
Tim
If you want to go a different route, go with Spotify premium. It streams at 320kbps, and you have access to an amazingly huge library. You can also make playlist and listen to 320kbps quality offline. They stream in an ogg vorbis format, it that matters to you at all.
shortylickens
80,287
17,082
How so? Hard drives are in the terabytes!
Honestly, OP, I buy CDs and rip them to wav for computer or headphone use. Otherwise, I use the CD in my stereo's cd player. I've had to many instances of downloading mp3 files only for them to develop some sort of audible pop, crack, or other defect; or simply get corrupted.
The level of quality is related to your end use. If used with inexpensive headphones or ear buds in a casual setting, or in typical car scenarios, or background music, you can get away with pretty low quality like 256 kbps mp3 or even 128. Amazon is pretty decent for this if you don't want to use iTunes (can't blame ya).
It would take all week to download a terabyte.
ZaneNBK
1,674
That used to be one of the better things about allofmp3.com back in the day. Choose whatever encoding and bitrate you like including lossless.
Of course the price was also nice, average of $0.10-0.15 per song depending on the size of the encoded file IIRC. :)
JimKiler
3,561
206
iTunes is AAC, not MP3, so it should be higher quality.
iTunes has been 256kbps for several years now. And it's AAC rather than MP3, so technically it's of higher quality (not that very many people can tell the difference).
Best answer right there.
I read on the internet that both MP3 and AAC at high quality +128bit are nearly identical, where the codecs really show differences is with the low bitrate stuff under 128kbps.
DaveSimmons
40,730
670
In my totally unscientific testing, 160 kbps AAC was as good as 192 kbps MP3, but at the 256 kbps rate that Amazon offers for MP3s you're unlikely to hear any difference from AAC.
Vdubchaos
10,408
10
Neither is as good as CDs ripped to lossless compression, sorry. For music that really matters, get the CD and convert it yourself.
Yeep
This is what I do, but quality matters and I don't mind ripping it (usually have it sent from Amazon anyways).
Once copied, CD never gets used again (in most cases)
momeNt
9,290
352
Keep with 128 and just upgrade your headphones to Beats. The upgrade in sound from anything to Beats will be greater than going from 128 to 256, or even lossless for that matter.
Upgrade equipment before source, the best advice anybody can ever give you.
SphinxnihpS
8,368
25
First of all CD quality is not magic and nothing ripped from a CD can be very high quality because the source is not. High quality would be like 24 bit 192kHz. Very high would be like 32 bit 2822400kHz.
iTunes has a format called ACAD which is their own compression scheme packaged in .mp4 containers. It is lossless (probably 24 bit 48kHz/CDish). I do not know how much of their catalog is available in this format.
Staples
4,953
119
Itunes is probably your best bet. 256kbps vbr AAC is indistinguishable from CDs for 90% of music. And the rest? Well I probably couldn't hear the difference anyway.
biostud
19,957
7,050
Unless you have both very good audio equipment and very good ears, I doubt you'll be able to tell the difference between 256kbps mp3 and a CD.
mnewsham
14,539
428
Are you seriously recommending beats? or am I missing some sort of sarcasm?
I mean...what the actual fuck xD
Imp
18,828
184
I can't really tell that big a difference between iTunes and my CDs ripped at WMP variable bit rate. And I've beeing buying more singles than albums lately, so most of my shit comes from iTunes now:(.
Mar 11, 2004
23,444
5,852
There's a couple of other high quality music "shops" online but they're selection is limited and probably has little popular stuff on there, its mostly classical and jazz type of stuff.
Lynn Music is one. I can't remember the others (as mentioned HDTracks is probably your best bet).
CD is about your best option but that's a total crapshoot as well as there's a lot of "remastered" ones out now that sound atrocious. Maybe hunt down SACDs, actually streaming DSD seems to be the most recent popular audiophile goal. That and vinyl of course.
I think you mean ALAC and that's just a lossless codec like FLAC (so it could be just about any bitrate and resolution) and they don't sell music in that format.
NutBucket
27,154
635
Yep, no DRM from Amazon.
PLUS! Now when you buy LPs Amazon provides you with downloadable files too! Now that's convenient!
Childs
11,313
7
Bandcamp allows you to pick your format, but the selection of popular music isn't as big as Amazon or iTunes. Its mainly for smaller/indie bands, although I have found some commercial stuff on there.
Staples
4,953
119
Yes.
Srsly, just use iTunes.
There is definitely some stigma here of since it is Apple, there must be some kind of catch.
But there is none, I have been buying from iTunes since they opened. It is easier to find stuff and easier to download than Amazon, especially now since they make you download their crappy cloud player app.
Anyway, there is no DRM and hasn't for 3+ years. It is 256kbs AAC and they sound great and can be played on anything. That is all anyone needs to know. Amazon is fine too with their 256kbs mp3 but I find iTunes just makes it simpler.
