Another update:
I'm now at, 2501MHz@1.710v (!) (although it does undervolt by ~0.5v)
I'm running at a FSB of 278MHz, HT Freq. is at 4x, memory divider set at 166MHz (RAM speed ~230MHz), 8-3-3 CAS 2.5 and at max 2.85v
Northbridge voltage I've left alone as I have a Zalman Passive NBJ45 (blue) on there right now and even at default volts seems to get almost too hot to touch after a heavy session.
I haven't had the chance to give it 24 hours of Prime95 just yet, but I've given it a good session of S&M (v1.5.1) and that seemed to max out the CPU temp at 59C (ambient room temp is 26C). I know that 59C is a little high, but to be honest, I doubt that anything will ever push the CPU to that much heat. S&M seems to do someting else to achieve such a high temp. I'll leave it on overnight running Prime95 to hopefully test full stability.
I actually reset my board back to defaults to test out some stuff. In my case, HT Freq. 1x, 1.5x, 2x, 2.5x all work up to 330MHz. I'd settle for this, but unfortunately, the only memory divider that works for me at such a high speed is 100MHz (0.5)! Which sucks! I've also found that 3x HT Freq works only as far as 257MHz (which I can't figure out why, esp as 4x works all the way up to 295MHz) - even if I push the max amount of volts through the CPU (tried all the volt ranges inbetween too). The only mem dividers that I can seem to use at the higher speeds (>250MHz FSB) are either 100MHz or 166MHz. All the others don't work! Maybe it might just be my RAM?
I think that I'm calling it a day for now (at least until MSI release a new bios revision), I'm at 2.5GHz, which is what I wanted, good luck to everyone else...
Oh yeah, before I forget, I alos posted this in the other thread, but have any of you managed to successfully boot from a USB key/stick? I have my Sandisk Cruzer Micro (which I know is bootable), but none of the bios options (USB-FDD, USB-Zip, etc) (or 'Boot Other Device') seem to allow me to boot it - but it detects that that stick is there on bootup. Even going through all the boot options on pressing F11 on startup, yields no luck.
