intricate45
I just got a new 120mm 5 bladed SUNON 5.4 Watt fan from the computer show (ball bearing)-a quick mount to the case frame showed that it dropped the CPU temp to 89F from 98F=nice.
Does anyone know any web sites where I can get the mounting screws for this fan frame and a site where I can buy 92MM and smaller fans for a reasonable price? I like relative quiet but good air flow and want to keep my AMD XP 1700+ CPU cool.
I have an old FULL TOWER ATX style case and what would you recommend I use in the way of fans in the case? Whats the best way to cut out the holes for the fans to mount in the side case panels? I am not a mechanic or tool shark.
I am using an el cheapo $12 AOC hsf now and wil replace that in the future-I AM NOT OVER CLOCKING NOW!
Thank you-
Thank you-
