- Oct 13, 2004
- 7
- 0
- 0
After my previous post concerning cooling solutions for a MicroAXT Gigabyte EG43M-S2H. I have somewhat narrowed down my choices to the two coolers listed below. They both meet the height requirements and have retention screw mounting hardware. After measuring the motherboard I have 4 1/2" from the Northbridge heatsink to the edge of the mobo. I am still uncertain if each cooler will clear the components on the mobo. The Masscool 8WA741 has a smaller footprint but I don't know if there is enough height from the chip to the bottom heatsink fins. The ASUS V60 has a larger footprint and seems to have the height from the chip to bottom heatsink fins, but I an worried the heatpipes will interfere with the Northbridge heatsink. If anyone has experience with these two heatsinks or the Gigabyte EG43M-S2H board I would like to hear them. I am also open to other suggestions.
MASSCOOL 8WA741 92mm Ball CPU Cooler
http://www.newegg.com/Product/...x?Item=N82E16835150082"]http://www.newegg.com/Product/Product.aspx?Item=N82E16835150082[/URL]
Model
Brand MASSCOOL
Model 8WA741
Spec
Type Fan&Heatsinks
Fan Size 92mm
Compatibility Intel: Socket LGA775
CPU: Extrerme Edition, Prescott, Celeron D, Core 2 Due, Core 2 Quad, Core 2 Extreme, Dural-core, Pentium D
Bearing Type Ball
RPM 2800 ±10% RPM
Air Flow 50.61 CFM
Noise Level 34.58 dBA
Power Connector 4 Pin
Physical Spec
Fan Dimensions 92 x 92 x 25mm
Heatsink Dimensions 95 x 95 x 104mm
ASUS V-60 92mm Vapo Bearing CPU Cooler
http://www.newegg.com/Product/...x?Item=N82E16835101011"]http://www.newegg.com/Product/Product.aspx?Item=N82E16835101011[/URL]Model
Brand ASUS
Model V-60
Spec
Type Fan&Heatsinks
Fan Size 92mm
Compatibility Intel Core2 Extreme/ Core2 Duo/ Pentium D (Dual-Core)
Intel Pentium 4 HT/Celeron D all series
Bearing Type Vapo Bearing
RPM 2300 ±10% RPM with PWM
Air Flow 36.5 CFM
Heatsink Material Cu. Base + Al. Fins + 4 Heat Pipes
Physical Spec
Heatsink Dimensions 106 x 107 x 118mm
Weight 630g
GIGABYTE GA-EG43M-S2H LGA 775 Intel G43 HDMI Micro ATX Intel Motherboard
http://www.newegg.com/Product/...x?Item=N82E16813128354"]http://www.newegg.com/Product/Product.aspx?Item=N82E16813128354[/URL]
-FridayXIII
Model
Brand MASSCOOL
Model 8WA741
Spec
Type Fan&Heatsinks
Fan Size 92mm
Bearing Type Ball
RPM 2800 ±10% RPM
Air Flow 50.61 CFM
Physical Spec
Brand ASUS
Model V-60
Spec
Type Fan&Heatsinks
Fan Size 92mm
Air Flow 36.5 CFM
Physical Spec
Weight 630g
-FridayXIII
