need XP help, how do i change the drive letter
SLEEPER5555
1,597
i currently have a D:/ and i want to change it to E:/ because i have a new D:/ but it remembers the old drive as D:/ and wants the newone to be E:/ but i want it to be D:/ not E:/, how do i do this i have tried to uninstall both drives and reboot with just the new D:/ but that does not work it reinstalls as E:/ even if at the moment there is no D:/. This kinda sounds like a riddle doesn't it! OK NOW HELP ME!
corkyg
Elite Member | Peripherals
27,370
240
Try Control Panel, Administrative Tools, Computer Management, Disk Management. You should be able to select and rename drives there. You may first have to set old D to something way up there, then change E to D and lastly "way up there" to E.
