Need Wireless Access Point Recommendation
LuNoTiCK
4,698
I need a good wireless access point that is not ubiquiti.
I have one, and it's been nothing but problems, I presume it's defective. I haven't had much help from ubiquiti's support (they keep telling me to update this firmware, that firmware, send them new files, etc) , so I would like to buy a new one that is non ubiquiti.
I need fast and stable please.
JackMDS
29,543
421
VirtualLarry
56,570
10,205
Some of the Amazon reviews for the Asus AC1200 router, claimed that at least the 2.4Ghz signal had great reach, through multiple walls, out into the garage, etc. Don't know about its 5Ghz signal.
I ordered one of those earlier tonight, then I ordered the "G" model, as the normal one apparently isn't Gigabit wired, and I overlooked that fact, when I was comparing prices. Oops.
Prime2515103
75
Can I ask what model your Ubiquiti is?
My wireless died and I have had such a great experience with their Edgerouter wired router I was considering one of their AP's.
aigomorla
21,034
3,517
So wait did you update the firmware?
I assume you are also running them off the Unifi Controller?
That being said, you are not going to get better then ubuiquiti unless you pay for it.
Ruckus makes great stuff, a bit cheaper then straight up Cisco, but still double the price of a comparable Unifi Pro.
https://www.amazon.com/Ruckus-Wirel...spons&keywords=ruckus+wifi+access+point&psc=1
I have also heard this Zytel soltuion is pretty good as well:
https://www.amazon.com/dp/B0776XPP6G/ref=sspa_dk_detail_4?psc=1
If you want cheap... This TPLink unit is acceptable...
https://www.amazon.com/TP-Link-AC19...533659819&sr=1-6&keywords=tplink+access+point
But of course if money was no object, id probably go the Cisco Aironet solution, and not look back.
mnewsham
14,539
428
The problem most people have with ubiquiti is the learning curve. If you don't know much about networking, don't buy ubiquiti, they're enterprise grade hardware, without the support.
Genx87
41,091
513
Ubiquiti is pretty easy to learn. Honestly, a standard out of the box setup is easy to put up. I am curious what issues the OP was having. And did he\she upgrade the firmware?
LuNoTiCK
4,698
I bought the Ubiquiti UAP-AC-Pro.
My wired connection is stable as a rock, it's only the access point which has the issues. Tech support transferred my case to level 2, but at this point I'm tired of it.
Which Cisco Aironet would be recommended?
rchunter
933
72
I would get ubiquiti to RMA and try another one. You probably just got a bad one.
PliotronX
8,883
107
I can relate to being sick of talking about it and I know from personal experience how god awful ubiquiti support is, but do you mind if I ask what kind of issues are being encountered? Is it with all devices or only certain types? I ask primarily because you may encounter the same with another solution and then you've got more gear thrown at it to deal with.
rmd2001
273
I've had 2 Engenius EAP600 - they were so-so (interface was from 2000 or earlier). Dropped clients. Replaced them with two Ubiquity UAP-AC-PRO. Very happy. They are not perfect (I hate to have Java in order to use interface). Handoff is working. Clients not dropping. They are not hard to master unless you are on "networking for dummies" level.
LuNoTiCK
4,698
All connections just get dropped several times a day.
