Need TV suggestions: Plasma or LCD
minendo
35,560
22
My dad called and said they want to buy a flatscreen to hang on the wall in the living room. Such TVs are not ones that I keep up with so what is the best option for <$3000?
RossMAN
Grand Nagus
Feb 24, 2000
78,943
405
Either Maxent 50" @ BB or CostCo's HDTV sale.
* Panasonic 50" Plasma 1366x768 3000:1 HDMI HDTV-Ready for $2,999.99 after $300 off (Jan 9 to Jan 15) Model # TH-50PM50U
* Philips 50" Plasma HDTV 2HDMIs, Tuner, 1366x768, $$2599.99 ( Jan 23 to Jan 29)
* Sony 32" LCD HDTV-Ready BRAVIA Feb 27 to Mar 5
* Sceptre 42" 1920x1080 LCD HDTV - $500 off the price... (True 1080p!!!!!!!!!!) Mar 6 to Mar 12
* Vizio 42" Plasma HDTV for $1500 (drooooool)
Oct 20, 2005
10,978
44
Plasma if you can afford it, otherwise LCD...although both Plasma and LCD in the higher inches range are both relatively expensive.
The Samsung 50" Plasma looks freakin nice. It's like $4,000 MSRP tho.
imported_electron
427
I once saw someone say, get LCD for something inches or less, and plasma for something inches or more. If only I could remember how many inches that was. I think it was around 40" but not sure. So it went like this: get LCD for <40" or Plasma for >40".
MrDudeMan
15,069
94
Originally posted by: Scouzer
i thought plasmas were crap becsause they have such a limited life?
not true at all. this rumor is perpetuated by people who have no clue (not talking about you since obviously someone must have told you that). the lifetime of a plasma TV is very long, even though they do tend to be a tad shorter than LCDs. the newer plasmas have lifespans of 60 to 80 thousand hours, which is up to 12 hours a day for 20 years.
keep in mind the 'lifetime' rating is the amount of time it takes for the TV to be at half brightness, which for a plasma will end up being brither than an LCD since they tend to have higher brightness out of the box.
fustercluck
7,402
DLPs and Projectors are total crap compared to plasmas/lcds, just go compare the different kinds of TVs at a big entertainment place like Circuit City. I think Plasmas are the nicest though. Check out the 50" Vizio plasma at Costco, the picture looks really nice and it's got a lot of positive reviews, i'm contemplating getting one now myself.
BillyBatson
5,715
go with Plasma as long as you need a 42" screen and up, WAY better picture and far cheaper than LCD's aroudn the same size.
if you need less such as 37" and smaller your only choice is LCD =\
