Originally posted by: simms
you want to lose weight? actually do some cardio. DDR won't help. IMHO, 5th mix is best. you'll have to do the 9 stars, paranoia... naoki underground's insertion... the mats, any will do. the hard ones will run you around 160US. soft ones , all are pretty much the same.
still, you want to lose weight, www.johnstonefiteness.com, or www.geekfitness.com will do you wonders.
Originally posted by: MacBaine
Padding = yes.
I've found that padded mats will detect steps much better than non-padded. Tape them down and it's great. Also better on the feet.
I would also go with a PS2 instead of a 1... get DDR max, tons of great tracks. Sure it isn't as great a workout as jogging or something, but it's a lot more fun, and will still get your heart rate up pretty good.
Padding = yes.
I can't afford a PS2. PS1 is much cheaper. I'll only be using it for DDR too, so PS2 would be a big ol waste (I really don't like playing anything on the PS2)
