need to help a teacher out asap!!
AnimeKnight
Hello.. I need help as soon as possible!! I am helping a teacher opening up a file according to her it's a pagemaker file that was sent by another teacher. She needs to open the file up and print like 60 copies for the students. I offered to help her because I have pagemaker however I can't seem to open the file!! it doesn't have an extension so I think the other teacher must have done it through Macintosh is there someone that can help me open this file? I have tried changing the extension to .p65 because I have pagemaker 6.5 but no luck.
here is the file where you can down load it file it's zipped
thank you in advance
I don't have pagemaker, but I d/l-ed your file, added the extender of .txt and loaded it into notepad. Down near the bottom the file is identified as Pagemaker 5.0.
Add the pagemaker file extender to it. Then try to open it again.
AFAIK the apple/pc files are completely interchangeable.
can't help you with your file either, but as a sidenote, I'd remove your ICQ files (2000b) from your server, if you don't want people reading your messages or stealing your password!!
P.S.: what did you do to deserve such a message from a mod??
it wasn't suppose to be inspiring. It's something my girlfriend made for our 5th year anniversary. but then I guess you probably won't appreciate the amount of time and energy she spent on it.. cuz i bet you don't have a relationship that lasted that long 😉
