need sub $500 netbook for work.
lau808
217
this will be used in the field. work on a sugarcane plantation on maui. researching ditchflow and need to use while running our hydrology equipment. doesn't need to be top notch. the researcher that trained me was using a netbook with an atom in it but id prefer something better than an atom. can be notebook too. my budget is $500. will be buying from newegg and shipping to Texas. then it will be mailed here. i will also be looking newegg. thanks in advance.
MarkLuvsCS
740
I have a few options that will hopefully make it a little easier picking one out. I'll try to point out a few of the things that are different. Article discussing some of the netbooks
$500 - Lenovo Thinkpad x130e
11.6" 4lbs @7:40 battery life, E-300 @ 1.3ghz,11.6" x 8.5" x 0.98"
$450 - Sony VAIO YB Series (silver is $40 cheaper than pink or black)
11.6" 3.2lbs @4:20 battery life, E-450 @ 1.65ghz, 11.42" x 7.99" x 0.99"-1.25"
$450 - HP Probook 4430s review of hp
14" 4.5lbs @4:45 battery life(review), 2nd gen core i3, 13.35" x 9.25" x 1.11"
I'm not sure which factors are most important to you, but I hope I gave you some solid choices, especially considering sales on some of them ($100 off HP) ($50 off Sony). I figure you could easily decide if you would prefer the Battery Life (Lenovo), raw power (HP) or somewhere in between (Sony).
yhelothar
18,409
39
If you're like most ATers and don't mind a bit of customization yourself, you can get a super mean ass system for $300 used.
1.6GHz Core2Duo/80GB SSD 12.1" 3.6lbs @ 6hrs with 8cell battery
http://www.ebay.com/itm/Lenovo-Thin...tops_Nov05&hash=item1e6d25d8bf#ht_1110wt_1012
X61 thinkpad for $154 without a hard drive or power adapter
Get an intel 80GB SSD for $140
http://www.newegg.com/Product/Produc...82E16820167049
hard drive caddy for x61 for $3.50 here
http://www.ebay.com/itm/New-Hard-Dr...C_Drives_Storage_Internal&hash=item27c51fd178
Power adapter for $15
http://www.ebay.com/itm/IBM-Lenovo-...ers_Chargers&hash=item1c25d2e1e4#ht_782wt_932
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
If you're like most ATOTers and don't mind a bit of customization yourself, you can get a super mean ass system for $300 used.
That's a pretty good deal. ThinkPads are supposed to be pretty durable little mothers, and you never know, the tablet aspect could come in handy for the OP, though he'll need a disk to install XP, so maybe just update it to 7 and call it a day?
yhelothar
18,409
39
Any particular reason for the intel SSD over someone else? Crucial M4 128GB is down to like $150 these days.
Yeah... I'm a noob to SSDs, and the early reputation of intel has still stuck with me.
Interesting to see that there are a lot of better alternatives now. :thumbsup:
TheStu
Moderator
Sep 15, 2004
12,089
45
I wasn't sure if it was for reliability reasons, the intel ones I think still get high marks for that. But the Crucial M4 is overkill for this anyway, it is a SATA3 device and the x61 is SATA2.
lau808
217
ok thanks guys. definitely want and e450 i guess. i will look into these suggestions this coming week. thank you, keep em coming if you got more :)
wirednuts
7,121
4
actually, if he is using it for monitoring work that means it probably wont be moved around much while its in use... and in that case a larger screen in better too... so 15" would likely be ideal
but at that size and price, a CULV or even a sandybridge i3 should be a much better choice imo. much much better in fact....
dont get me wrong, i use an n270 atom netbook as my main everyday laptop... but it moves constantly, banging and falling all over the place. in my case i can sacrifice speed for durability and cost of replacement :D (some netbooks are built really tough btw!)
RU482
12,689
I've got the Lenovo x120e with the AMD E-350. I can't even use my Atom netbooks anymore after having this. Plus, gets 6+ hrs of battery life, doesn't run warm.
