Need some serious help
iKickCats
PLEASE READ BEFORE COMMENTING
Alright well I have a dielma of sorts I want a gaming lap top I found this http://usa.asus.com/Notebooks/Gaming_Pow...ifications but a lot of people are telling me that gaming lap tops usually last only about 2 years if they're mostly used for gaming is this true? I want the gaming lap top mostly for mobile gaming and school. Truthfully I don't want to go into high end type of gaming just tf2 cs:go mods dayZ and warZ. Can someone link me to good gaming laps or should I just build the desk top *keep in mind I have a 360 and I doubt I'll be doing hardcore high end games on the desktop*.Also if the above lap isn't good mind linking me to some that are good I have 800~1k spending limit also I don't care about wight size.
Your link doesn't work. Can you fix it?
ASUS is a pretty solid brand, and 1k will easily get you a nice mid-range gaming laptop that will last you for a little while.
Yup, looks like a fine machine for your needs. If it's in your budget, I say go for it.
It's a good machine that should stay fairly relevant for lower spec'ed gaming (like you mention) for 3-4 years depending on what you get into later. It's no secret that PC hardware evolves quickly and it's easy to get a few generations behind, but your demands are relatively low so this should be good for a bit longer than most.
I purchased an Asus laptop(refurbished) for gaming about two years ago and it has served me very well...Asus is a top notch brand. However, the mode G75vw you mentioned comes in many different configs...check it out on Amazon. The least expensive is around 1100.00 with not very good specs. The price goes up from there to close to 2000.00.
Thanks everyone! Now, for dumb question #1 can the lap top I posted above handle dayz,warz and all the games I mentioned above?
It should do just fine with the games you mentioned.
One thing to keep in mind that it sometimes pays off to buy low specs on parts you can change yourself. Such as Hard Drive and Memory. As far as Processor and Video card you want as good as you can and if a new option is on the horizon it might make sense to wait a few weeks.
