- Mar 21, 2001
- 84
- 0
- 0
<< My Linksys BEFSR41's dhcp support for automatically assigning up addresses to it from my cable connection provider does not include 255.255.254.0 (Class C?) subnet masks... which makes it basically impossible to use my connection on more then one computer currently, since I can't use the router. >>
Ok, now after devling deeper into the problem and having a greater understanding of how the router configuration works, the drop down menu is most likely for assigning a subnet mask for the local area network, not for when it is connecting through DHCP, with which it should automatically get the subnet mask from my provider.
I still cannot connect through the router though... I have the MAC address cloned, the latest firmware, the proxys typed in, checked and rechecked..
Someone from work said it could possibly even be looking for my machine name instead of/as well as the MAC address... but that does not make sense as I have been able to connect fine, without using the router, on a few different computers...
Any ideas?
