Need some registry help (settings) for XP
iwoodfu2
I fubared my registry accidentally and now I cannot open applications at all. If someone would kindly post the contents of the exported key of the HKEY ROOT CLASS
of the whole of what is under HKEY_CLASSES_ROOT\exefile\ I'd be greatful.
I believe that's the registry setting that got deleted by ad-aware and caused this mess to begin with... sigh.
Key Name: HKEY_CLASSES_ROOT\exefile
Class Name: <NO CLASS>
Last Write Time: 5/6/2003 - 9:11 AM
Value 0
Type: REG_SZ
Data: Application
Value 1
Type: REG_BINARY
Data:
00000000 38 07 00 00 8...
Value 2
Type: REG_SZ
Data: prop:FileDescription;Company;FileVersion
Value 3
Type: REG_SZ
Data: prop:FileDescription;Company;FileVersion;Create;Size
Key Name: HKEY_CLASSES_ROOT\exefile\DefaultIcon
Last Write Time: 5/6/2003 - 2:04 AM
Value 0
Type: REG_SZ
Data: %1
Key Name: HKEY_CLASSES_ROOT\exefile\shell
Key Name: HKEY_CLASSES_ROOT\exefile\shell\open
Value 0
Type: REG_BINARY
Data:
00000000 00 00 00 00 ....
Key Name: HKEY_CLASSES_ROOT\exefile\shell\open\command
Value 0
Type: REG_SZ
Data: "%1" %*
Key Name: HKEY_CLASSES_ROOT\exefile\shell\runas
Key Name: HKEY_CLASSES_ROOT\exefile\shell\runas\command
Value 0
Type: REG_SZ
Data: "%1" %*
Key Name: HKEY_CLASSES_ROOT\exefile\shellex
Last Write Time: 12/12/2003 - 4:22 PM
Key Name: HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers
Last Write Time: 12/20/2004 - 7:19 PM
Key Name: HKEY_CLASSES_ROOT\exefile\shellex\DropHandler
Value 0
Type: REG_SZ
Data: {86C86720-42A0-1069-A2E8-08002B30309D}
Key Name: HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers
Key Name: HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\PifProps
Value 0
Type: REG_SZ
Data: {86F19A00-42A0-1069-A2E9-08002B30309D}
Key Name: HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\ShimLayer Property Page
Value 0
Type: REG_SZ
Data: {513D916F-2A8E-4F51-AEAB-0CBC76FB1AF8}
adaware only deletes what you tell it to delete
yeah well it said it was the setting was "possible virus", so I deleted it then when I tried to run regedit again it didn't let me.
Value 0
Type: REG_SZ
Data: Application
Value 1
Type: REG_BINARY
Data:
Value 2
Type: REG_SZ
Value 3
Type: REG_SZ
Value 0
Type: REG_SZ
Data: %1
Value 0
Type: REG_BINARY
Data:
Value 0
Type: REG_SZ
Data: "%1" %*
Value 0
Type: REG_SZ
Data: "%1" %*
Value 0
Type: REG_SZ
Value 0
Type: REG_SZ
Value 0
Type: REG_SZ
Copy and paste the text from an EXPORTED file, so I don't have to retype it thanks.
Value 0
Type: REG_SZ
Data: Application
Value 1
Type: REG_BINARY
Data:
Value 2
Type: REG_SZ
Value 3
Type: REG_SZ
Value 0
Type: REG_SZ
Data: %1
Value 0
Type: REG_BINARY
Data:
Value 0
Type: REG_SZ
Data: "%1" %*
Value 0
Type: REG_SZ
Data: "%1" %*
Value 0
Type: REG_SZ
Value 0
Type: REG_SZ
Value 0
Type: REG_SZ
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\exefile]
@="Application"
"EditFlags"=hex:38,07,00,00
"TileInfo"="prop:FileDescription;Company;FileVersion"
"InfoTip"="prop:FileDescription;Company;FileVersion;Create;Size"
[HKEY_CLASSES_ROOT\exefile\DefaultIcon]
@="%1"
[HKEY_CLASSES_ROOT\exefile\shell]
[HKEY_CLASSES_ROOT\exefile\shell\open]
"EditFlags"=hex:00,00,00,00
[HKEY_CLASSES_ROOT\exefile\shell\open\command]
@="\"%1\" %*"
[HKEY_CLASSES_ROOT\exefile\shell\runas]
[HKEY_CLASSES_ROOT\exefile\shell\runas\command]
@="\"%1\" %*"
[HKEY_CLASSES_ROOT\exefile\shellex]
[HKEY_CLASSES_ROOT\exefile\shellex\DropHandler]
@="{86C86720-42A0-1069-A2E8-08002B30309D}"
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\PifProps]
@="{86F19A00-42A0-1069-A2E9-08002B30309D}"
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\ShimLayer Property Page]
@="{513D916F-2A8E-4F51-AEAB-0CBC76FB1AF8}"
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\{B41DB860-8EE4-11D2-9906-E49FADC173CA}]
Instead of mucking around with the Registry, why don't you use System Restore to go back to a save point before you made the changes?
Adaware shouldn't have damaged any registry entries itself. What probably happened is you had a really nasty spyware app like CoolWebSearch that inserted itself into the registry in such a manor that it's removal damaged your registry.
I've found Adaware to be a bit careless in this regard. For this and several other reasons Adaware has been off my radar for 8 months now. I use Microsoft Anti-Spyware or Webroot's SpySweeper when cleaning client's systems.
I believe the default process in Adaware is to back up the last action you performed (you can manually add additional backups). If you click the "Backups" button on the first screen in Adaware, you can restore whatever you deleted - assuming the date of the file is the same date as the last action you performed (which is what you're stating is the date your problem occurred).
Edit: You should always opt to backup before you make any changes in your registry.
