Hiyo, Looking to pick up one stick of 512MB RAM in a couple hours. It will be single channel, since I don't see the point in spending an extra 40 CDN for 2-3% increase in performance (Will be grabbing a mobile XP 2500+). I just need some advice on RAM, it will most likely be OCZ. Mostly like 512MB (will get another 512 later when i could afford it). My options for OCZ ram are as follows:
- 512Mb DDR466 Rev2 Gold Edition (2.5-3-3-7) (EL Special Edition) - $230
- 512Mb DDR400 Platinum Edition (2-2-3-5) (EL Special Edition) - $220
- 512Mb DDR433 (2.5-3-3-7) (Performance Series) - $184
- 512Mb DDR433 (2-3-3-7) (EL) - $232
- 512Mb DDR433 (2.5-3-2-8) (Enhanced Bandwidth) $245
Looking to overclock just a bit over 200 and achieve around 2.4Ghz, that's why I only have one DDR 400, cus I'm pretty sure they won't be as stable as DDR433 and up. If you have any other OCZ options, let me know.
Thanks!
__________________
Thanks!
__________________
