Need some OC advice
mikef07
44
I have a 1800XP+ Thouroughbred. I have it at 1.7 volts (up from 1.6) and am running it at 160X12.5=2000 Mhz. (Stock is 133X11.5)
Is this accetable? I ran Prime 95 for about 45 minutes with no problems and it hits 38.5C according to hardware doctor from ABIT. Is this torture testing good enough?
ChampionAtTufshop
2,667
go for longer, about 5-6hrs or so of prime95 and 3dmark2001 loops
if it doenst crash/restart/wahtever, its pretty damn stable
is that a tbred a or b?
mikef07
44
It says something like JIUHB and it is 02/52 (Week 52 of 2002).
THe great thing is that all this comp is for is Edonkey and Movie Encoding with DVD2ONE
mikef07
44
Abit AT7. Not AT& Max jsut an AT7. I am pretty happy with 2ghz. I only have PC2100 memory.
ChampionAtTufshop
2,667
oic
well then yah i think 12.5x is the max mult you can get
and id ont think pc2100 will go much past 160
although you rpobably should go for 166 as thats when the 1/5 pci divider will kick in
right now you are stressing your pci devices quite a bit
mikef07
44
I have the Ratio at 5:2:1. I think I am underclocking a bit. Since I will never game on this machine, in fact no mouse or keyboard connected to it, I think it's ok to be underclocked. I only connect remote desktop connection. That's to start encoding and stop encoding.
