- Aug 22, 2016
- 255
- 20
- 51
I'm not sure whether it is the right place for this. Please correct me if I'm wrong.
My friend has got Kodi and he wants me to setup VPN on it. I personally use a premium vpn but I ain't willing to set it up on it. So I looked for a way out and here's what i have found:
So I just wanted to confirm whether it will require the premium sub of mine or can it work without it?
Thanks in advance
- Open Kodi
- Go to SYSTEM and then File Manager.
- Click Add Source.
- Choose None.
- Type the given address: http://fusion.tvaddons.ag
- Click done.
- Select the box that says enter a name for this media device and input the name fusion.
- Click ok.
- Go to the Kodi app on your Home Screen.
- Click System.
- Go to Add-ons from the pane.
- Then click install from zip file.
- Click fusion.
- Then click XMBC-repos.
- Select English.
- Click metalkettle-x.x.x.zip and then wait until the Add-on enabled prompt is shown.
- Click Install from a repository or Get Helix Add-On.
- Then click MetalKettles Addon Repository.
- Go to Program add-ons.
- Now click OpenVPN.
- Click Install and wait for the Add-on enabled prompt to show up.
- Click VPN for OpenELEC.
- Finally, click Install and wait for the Add-on enabled prompt to show up.
Thanks in advance
