I need some help guys. I've got 4 IDE devices I need to install in a system. How would you recommend setting them up? They are:
30GB IBM 7200 ATA100 hard drive
10GB Maxtor 5400 UDMA33 hard drive
36x cd-rom
Internal Iomega Zip drive
Is it true that if I use the IBM drive as the primary master and the Maxtor drive as the primary slave the IBM drive will only run as fast as the Maxtor? And also, can I hook them on the same IDE cable, or do they require different cables? Whatever I do I do not want the IBM drive to be slowed down by anything. If that means leaving the Maxtor drive out of the system then that's what I'll have to do. (Although I was hoping to use it for back-up and mp3's).
Would it make any difference if I put the cd-rom or the zip on the primary slave? Once again, I'm not even sure if this is possible if they use different cables.
Anyway, any suggestions? Thanks.
36x cd-rom
