CorCentral
Banned
(Going by the Intel 865 PERL Manual)
I'm using an ANTEC SX835II case and Intel 865 branded MB .
First question would be : Do I have to worry about Positive/Negative type connections ? (a certain color wire to a specific pin ?)
Reset Switch ----- CHECK
On/Off ----- CHECK
HD LED ----- CHECK
PWR LED ----- There are two places for this as the manual describes (Front Panel Header labled as ""C"" & another seperate from all the other connections labled "Power LED" , listed as ""D"" in the manual .
If I connected the PWR led to the place I think I should (with all the other FP connectors ""C"") One of the wires would not be connected to a pin .
Please post what you can if you can , as anything will help 🙂
Thanks ..............
Any input would be very much appreciated 😉
On/Off ----- CHECK
HD LED ----- CHECK
