Originally posted by: cmetz
WannaFly, call Extreme and ask, but last time I checked you can't get copper gigabit connections on the 48Si - there is no small form factor mini-GBIC for copper yet. It's a bummer. You could get a media converter, but it'll probably be cheaper to get SX fiber boards for your file server. Watch out for the same issue when connecting dumb L2-only switches to the gig port (though, on EBay, gig fiber + a bunch of 10/100 copper switches are cheap right now, 'cause people don't much want them anymore).
Garion,
>Plus, you do take a minor performance hit.
Any L3 switch on which there is a measurable performance hit for doing L3 switching vs. doing Ethernet MAC switching, frankly, sucks. The two operations should be the same from the hardware's perspective.
The main reason to use L3 switching and VLANs here is that WannaFly has a chance now to do an every-station reconfiguration, and probably won't get that chance again. If he thinks he might want subnets - to separate traffic, to make ACLs easier, etc. - he better do 'em now. Otherwise, he'll have to go renumbering later, reconfiguring a whole lot of stations, and that gets ugly. If all he's doing is statically routing between VLANs on an L3 switch, this is as simple and easy as routing gets. Is it as easy as having everything in one big Ethernet? No. But it's not much worse.
