Need Semi-Budget System/Upgrade
sam8813b
I was looking to get a new case, mobo, cpu, videocard, memory, harddrive, and DVD Burner. Basically a full upgrade. What should I get to keep it under $800 shipped?
There are several threads around here with suggestions for similar budgets.
Generally I'd recommend
Antec case + PSU
A64 (3200+ or 3000+ 939)
a gig of value ram
seagate hdd
nf4 motherboard
nec dvd burner
6600gt videocard (or X800XL if you can afford that)
Do you need windows too?
Nah I got windows. My real dilemma is what Motherboard to get. I dont want to overclock at all, i just want something cheap and stable.
Chaintech makes a nice basic NF4 based mb for right around $100.
I got a Soltek K8TPRO and it's working great. That was right around $100 too.
ANTEC Life Style Series Black Case With 380W Power Supply, Model "SONATA"
Lite-On Black 16X DVD+/-R DVD Burner support Dual Layer, Model SOHW-1673S BK, Retail
Seagate 80GB 7200RPM IDE Hard Drive, Model ST380013A-RK, Retail
MSI "K8N Neo4 Platinum" NVIDIA nForce4 Ultra Chipset Motherboard For AMD Socket 939 CPU -RETAIL
AMD Athlon 64 3000+, 512KB L2 Cache, Socket 939 64-bit Processor - Retail
Chaintech nVIDIA GeForce 6600GT Video Card, 128MB DDR3, 128-Bit, TV-Out/DVI, PCI-Express, Model "SE6600G" -RETAIL
Geil Ultra Series Value Dual Channel Kit 184 Pin 1GB(512MBx2) DDR PC-3200 w/ Blue Heatspreader -Retail
Logitech X-530 5.1 Black Speaker System -RETAIL
Total (Before tax): $837.22
Hows that lookin?
Hows that lookin?
Is this the ram you're talking about?
Unless you're doing insane overclocking and insist on increasing the ram speed, you should be spending about $100 on a gig of ram.
Corsair value select is only $85 shipped at chiefvalue.
If you want to do some overclocking, twinmos makes some very nice ram that takes a lot of voltage and gets very nice timings. I think it's around $125 for a gig.
If you want the best performance/$, spending $250 on ram is not the way to do it. Spend about $100 on the ram and then spend the money saved on going with an X800XL or a 6800gt. You'll get much better performance in the end than you'd get spending so much on ram to get a couple more % increase.
with
Corsair Value Select (Dual Pack) 184 Pin 512MBx2 DDR PC-3200 - OEM
Seagate 160GB 7200RPM IDE Hard Drive, Model ST3160021A, OEM Drive Only
it is
Product total: $774.65 🙂
The Final Tally.
Antec Life Style SONATA Piano Black 0.8mm SECC Steel ATX Mid Tower Computer Case 380W Power Supply - Retail - $89
CHAINTECH VNF4/Ultra Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail - $94
CHAINTECH Geforce 6600GT 128MB GDDR3 PCI-Express x16 Video Card - Retail - $169
AMD Athlon 64 3000+ Winchester Socket 939 Processor Model ADA3000BIBOX - Retail - $146
CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR400(PC3200) System Memory Model VS1GBKIT400 - Retail - $85
Seagate Barracuda 7200.7 ST3160827AS 160GB 7200 RPM Serial ATA150 Hard Drive - OEM - $95
NEC ND-3520A Black IDE DVD Burner - OEM - $55.95
Logitech X-530 70 Watts 5.1 Speaker - Retail $55.99
SUBTOTAL
$789.94
SHIPPING AND HANDLING CHARGE:
$ 10.00
TOTAL:
$799.94 -- Chiefvalue.com
2nd. Oh balls, the chaintech uses a 24 pin atx adapter? Is the PS on the Sonata 20? Is there like a converter i can buy?
