T Tanker135 Member Oct 11, 1999 88 0 66 Mar 23, 2001 #1 I have 2K - 2.5K to spend. What's the best can I get out of it. System is mainly for game and surf the net with occasionally doing CAD works. 1. Minimum: 19 in monitor 2. DVD is not required Thanks in advance.
A AIRREAK Senior member Apr 6, 2000 332 0 0 Mar 23, 2001 #2 1st find the monitor you like, that could be the most expensive part and likely the thing you will keep the longest. 2nd get a good case with 300watt or so power supply. 3rd big decision Intel or AMD can't go on until you answer number 3
