Need motherboard for $70 or less to hit 3.0ghz with E2180?
quadomatic
993
Can someone give me a tip for the cheapest motherboard I can get so that I can hit 3ghz with an E2180?
Thanks
BlueAcolyte
2,793
what other features do you want? IP-35E or GA-P35-DS3L. spend a bit more ($20) for the DFi blood iron if you want.
quadomatic
993
I just want to spend less than $70 on the mobo. The only "feature" I can think of is PCI Express.
21stHermit
927
$69.99 + S&H.
Read the reviews, seems like a nice OCer.
quadomatic
993
I was looking about this. It seems decent, but I'm not positive about it. I'll look into it.
quadomatic
993
It's OOS
Not sure about the platinum anymore, can't find anything about oc'ing any E21xx with it
rogue1979
3,062
Asrock Conroe1333 D667 $47 at mwave.com
Just need to paint a couple of dots on the cpu to set it to a native 266Mhz fsb.
It will hit 350Mhz, faster than the 2180 will go.
If you haven't bought the cpu yet, a 2160 will hit 3Ghz with room to spare.
quadomatic
993
Thanks for the tip. This sounds like a hot deal.
By painting a couple dots, you mean BSEL mod of course. Do you have any guides to that please?
Thanks
UPDATE: Wow on this I can save. I can get an E2180 and this mobo for $139 shipped.
secretanchitman
9,353
23
you want the asrock 1333fsb mobo. i got mine from mwave for around $80 1 week ago. supports 45nm and has my favorite "amibios", so it'll overclock nicely. my pentium D is currently at 3.75Ghz, completely stable (250FSB).
Zap
22,377
7
Originally posted by: jaredpace
hey this 1 is better...
it has a p35 w/ sli and heat pipes all over
Crossfire, not SLI.
As for the ASRock board, Newegg has it for $49. There are two versions, one is the Conroe1333-D667 and the other one (looking identical) is the Wolfdale1333-D667. I'm guessing the latter ships with a 45nm capable BIOS. Note that while it does have FSB adjustments, you will have to raise the PCI-E speed along with it as the 945 series chipset only has a pseudo lock on the speed. If you leave PCI-E at 100MHz then you won't get good clocks. Additionally, while you can do the BSEL mod for FSB, the board does not give you Vcore settings so you may need to do the Vcore mod as well. Search VR-Zone for details on both of those mods. The board does have two voltage adjustments, one for memory and one for chipset. Settings are limited to something like NORMAL/HIGH. For any overclocking you'd want to set both to HIGH.
Have fun, and let us know what you end up getting and how it overclocks. :thumbsup:
