Originally posted by: Xylitol
Can you add folder on iTunes as your media library or no
Originally posted by: Baked
It only works if the files in WMP are MP3, perhaps.
Originally posted by: S Freud
EDIT: How does one usually get the songs into Itunes?
Ok, have you tried dragging the songs from where the songs are stored on your hard drive to iTunes instead of from WMP to iTunes?
Winner, thanks for the help. 🙂
Is there a way to drag more than one song at a time? At this rate I'll be here all night.
Now how do I get all of the songs on my Ipod? 😱
Originally posted by: OdiN
Here's the solution to all iPod problems:
Sell the piece of crap and buy a real MP3 player.
open up itunes while having a windows explorer window with all the mp3s that you want added, highlight all of the mp3s and drag them to itunes. it will then be added to your library. you can also add multiple folders this way.
up for a new question
I already answered every iPod question
Lol, seriously, I have the black 60gb ipod and I REFUSE to use itunes. Instead I would HIGHLY recommend this:
http://www.bestbuy.ca/catalog/proddetai...N&sku_id=0926INGFS10051068&catid=21152
PM me for step by step to convert any movie file to iPod compatible format.
first of all, thank you for thanking me for assisting you.
second of all, ever think to use google?
