Originally posted by: nealh
Originally posted by: Shimmishim
This is not my post but someone elses:
//start
Let me introduce my external watercooler to everyone .
Do you have a very expensive case that you don't want to have to cut up to fit all the components that a HIGHEND watercooling setup takes, Or maybe you have a SFF pc that is screaming for an overclock, but can't fit the radiator, pump, and tubing in that already cramped case, Or maybe your not comfortable with using the tools that are needed to modify the case with? That is why I make and produce the new WaterKegIII.
The WaterKegIII features a triple 120mm radiator (hence the III in the name) from Swiftech, Drain port, a Laing D5 pump, clear reservoir, and CCFL lights are among just some of the features this exclusively HIGH PERFORMANCE external watercooler includes. Installation of this external WaterCooler is VERY simple, all you need to do is drill "2" 1 inch holes in the back of your PCs case for the water tubes to go in and out from, and THATS IT, extremely easy considering the cooling and overclocking potential that this cooler provides. To power the WaterKegIII is as easy as powering any internal PC device. Using the PCI Pass Through Bracket (provided with purchase of cooler) connect the 2 molex power cables (provided as well) from the back of the WaterKegIII to the PCI Pass Through Bracket, thats it.
You can customize your cooler with these options:
1. CASE COLOR
BLACK, SILVER, BRIGHT RED, BROWN, COPPER, DEEP BLUE, DEEP GREEN, GRAY
2. MESH TOP COLOR
3. CCFL LIGHTS
BLUE, GREEN, RED, UV, WHITE
4. WITH OR WITHOUT D-TEK FuZioN CPU BLOCK.
5. THERMOCHILL PA120.3 RADIATOR (KingKegIII) + 149.00 (LIMITED AVAILABILITY ON THESE RADS, SO CHECK WITH ME FIRST)
All WaterKegs ship with Pentosin coolant additive, 2 molex power cables, 10feet of 1/2 tubing, hex key for drain valve, 2 rubber bushings for PC's case, a couple of zip ties, and quick installation instructions.
For the most part, I make my external WaterKegs on a "build to order" basis, customized from what you tell me out of the options provided. Usual time from start to shipped is around 3-5 "working" days
I have future plans to produce a more basic cooler using a double 120mm radiator called the WaterKegII . For those of you who just want to cool your CPU (single or dual core), and maybe the northbridge, this cooler will be less expensive, and really all you will need. PM me if you want/need one, and I'll start the building process ASAP.
As with any purchase, I will send you pictures along the way showing your cooler coming together (If you want me too )
Please, if you have any questions or concerns, PM me and I'll get back to you as soon as humanly possible
***I CAN NOT GUARANTEE YOUR OVERCLOCKING SUCCESS, AS WE ALL KNOW THIS IS IMPOSSIBLE TO DO, I AM ALSO NOT RESPONSIBLE FOR IMPROPER HANDLING, AND MISUSE OF THIS COOLER.
HERE ARE SOME PHOTO's OF THE WaterKegIII:
http://img255.imageshack.us/img255/7071/dscf0832zt0.jpg
http://img391.imageshack.us/img391/9889/dscf0847qi1.jpg
http://img338.imageshack.us/img338/5241/dscf0833tp7.jpg
http://img391.imageshack.us/img391/515/dscf0840at8.jpg
http://img251.imageshack.us/img251/3003/dscf0858ib4.jpg
http://img250.imageshack.us/img250/2001/dscf0859zp8.jpg
***PRICING***
WaterKegIII WITHOUT D-TEK FuZioN CPU BLOCK...................369.00
WaterKegIII WITH D-TEK FUZION ADD 64.00 DOLLARS = 433.00
ALL PRICES ABOVE DO NOT INCLUDE SHIPPING. PM ME AND I WILL QUOTE YOU ON THE SHIPPING
THANK YOU EVERYONE, AND HOPE TO MAKE SOME PEOPLE OUT THERE VERY HAPPY WITH THIS
TAKE CARE
//end
This is a prebuilt custom unit and it takes the guess work out of trying to put one together especially for someone that has no idea what he's doing.
excellent suggestion..I agree 100% with this
//start
1. CASE COLOR
2. MESH TOP COLOR
3. CCFL LIGHTS
***PRICING***
TAKE CARE
//end
ROFL... the infamous waterkeg made by a member named newls1 over at xs forums. :]
Yes this is a very nice setup, however, i think newls is in the process of tweeking it some more. Thats why it was pulled off his f/s forum over at XS. I could be wrong tho.
If you get this, make sure you request newls to throw in some quick disconnects. They will help you a lot when transporting.
And i cant tell you a aprox temp without knowing your blocks you have, the voltage settings your running, and ambient temps.
i ment infamous, as well known. Your work log was being followed by a lot of people including me 😀
This is naekuh over at XS forums.
I like your waterkegII. I know a lot of people that like your waterkeg, and ive been also promoting your waterkeg, for a possible external quad core solution. :]
BTW, why is your F/S thread locked over at xs forums?
