Need help with SQL query in MS Access
Descartes
13,968
<< Well for a class, using Access to learn SQL queries isn't a bad idea. Access does its job well for what it was designed for. It's just portrayed as such a crappy database because so many companies use it for something it was never designed for. >>
I agree. I'm just bitter from having assimilated many projects that were implemented extremely poorly with Access.
joohang
12,340
<< I agree. I'm just bitter from having assimilated many projects that were implemented extremely poorly with Access. >>
Heh.
I've been building an app called "Visual Spammer" ;) for a local user group. It's written in C# and takes a list of email addresses from any Access database to fire off an email to each member. Since it's designed for a single user app, it does its job well. :) I just gotta debug my crappy code since it's crashing so much. hehe
Funny how I know the guy who designed this Access database 3 or 4 years ago. He's a very good developer and now manages some big .NET projects. He got very creative with the database table names - using spaces and hyphens, etc. :) My app works fine with my own databases but crashes like crazy with his. Oh well.
Descartes
13,968
<< Descartes -- I changed the two to reflect what I want, which is to move down one year.
Would that be -1? I did that, and one of the tables it went from 2002 to 2000.
The other table went from 2002 to 1977???
Are you sure? I've never witnessed the behavior you describe. Run a query listing the date before, and after like so:
select yourdatefield, dateadd("yyyy", -1, yourdatefield) as yourdatefield_after from yourtable
I get the correct behavior.
LuckyTaxi
6,044
23
it works with '-1' when i run a query to update one table. querying more than one table will make the weird changes i mentioned earlier.
Descartes
13,968
<< He got very creative with the database table names - using spaces and hyphens, etc. >>
Hehe
select [every time], [i have to], [do this], [to my], [SQL statements] from [i get angry]
The last Access database that was thrown on me for "conversion", I found myself immersed in a database that consisted of one table, hundreds of thousands of records, and hundreds of columns. I think the original "developer" took the idea of denormalization for performance to the extreme? :D
I actually use Access quite a bit, but only as a "lightweight" database I can distribute with my smaller applications that have frontends in some other language. I'm also endlessly frustrated by query builders (and the fact that Access destroys my hand-typed sql statements). I have seen some clean uses of Access, but extremely poor ones are more common.
joohang
12,340
hehe. Yeah. That square bracket is a pain.
Now I deal with another problem. I found a field name with a space! It crashes my app because I am using XML conversion in DataSet and something fishy is going on here. Grrr.. :)
I hope I don't have to deal with regular expressions.. Oh god..
joohang
12,340
<< The last Access database that was thrown on me for "conversion", I found myself immersed in a database that consisted of one table, hundreds of thousands of records, and hundreds of columns. I think the original "developer" took the idea of denormalization for performance to the extreme? :D >>
LOL
<< I actually use Access quite a bit, but only as a "lightweight" database I can distribute with my smaller applications that have frontends in some other language. I'm also endlessly frustrated by query builders (and the fact that Access destroys my hand-typed sql statements). I have seen some clean uses of Access, but extremely poor ones are more common. >>
hahaha. Sounds like FrontPage and HTML, doesn't it? ;) Maybe it's a common feature among all Microsoft Office apps. :)
