MrControversial
Does anyone have this controller? I'm trying to use it to play Far Cry because the KBM is very uncomfortable for me. I programmed everything okay until it came to the left analog pad which I want to program to strafe and go forward and backwards while the right stick functions as the the look. After screwing around a bit, I finally got the right stick programmed as the mouse look. However, the left stick is proving to be a problem. I programmed the X and Y axes to left, right, up, down respectively, but due to the analog nature of the stick, when the stick returns to the center, there's a tendency for the software to interpret it as moving in another direction. It's hard to explain, but I'll try.
If I move the stick to the right and then let it go, the stick naturally returns to the center like it should. But then the software has a tendency to interpret that as a move to the left. It doesn't do this with the right stick. Am I programming it wrong?
