Win7 Home Premium cannot serve as a server, but you can use it to connect to other machines which are servers. (Win7 Home can use RDC to a Win 7 Pro, but Win 7 Pro can't RDC to Win 7 Home)
Can you ping your XP pro machine? Try using the IP to connect? Check to make sure XP Pro is set up to accept connections? Check firewall on XP pro?
