Need help with RAID system and power/cooling
klezmer41
I have some old stuff that I want to turn into a little server. I was thinking about getting this Lian-Li case:
http://www.newegg.com/app/ViewProdu...1-112-024&catalog=7&manufactory=BROWSE&depa=0
and getting the Promise SX6000 ATA RAID controller:
http://www.newegg.com/app/viewProductDesc.asp?description=16-102-006&depa=0
and the 550 watt Antec TruePower power supply.
This is what I have to put in it:
ASUS CUSL2-C mobo
1GHz P3
512MB PC133 RAM
Pioneer DVD ROM
Plextor CDRW
GeForce2 Ultra
NIC Card
3.5" Floppy Drive
1 ATA hard drive just for the OS
+ Promise RAID controller with 6 ATA drives attached
+ however many fans I can fit in there
I'm concerned that the case might be a little too small and not have adequate cooling ability. Also I would like to know people's opinions and experience regarding hooking all that stuff up to that size power supply. Thanks for any help!
Scott
mechBgon
Oct 31, 1999
30,699
Welcome to the Forums klezmer41. :)
For the other folks:
link to the case
link to the RAID card
Now, what do you need a six-drive RAID for in a home server? Unless you have a gigabit network, the data ain't goin' anywhere over your network any faster than about 10 megabytes per second (100-megabit/sec = 12.5 megabytes per second, and subtract some for overhead). If you're doing it strictly for failure resistance (RAID1 mirroring) then that might make sense. :)
I have a variant of that case and I wouldn't suggest putting 8 hard drives into it. Unless you modify the case, its cooling properties are not so good (mine is modified). I would suggest getting one of the Chieftec true full-tower cases, which have two separate 3-drive cages that both have 80mm fan mounts in them, and pair that up with your TruePower 550. Bonus: they're a lot less money, too, how's $65 sound? :)
